Ir para o conteúdo principal
Kyocera Event Battery Replacement
O que você precisa
  1. Kyocera Event Battery Replacement, Battery: passo 1, imagem 1 %32 Kyocera Event Battery Replacement, Battery: passo 1, imagem 2 %32 Kyocera Event Battery Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: passo 2, imagem 1 %32
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Conclusão
Jen Michaels
Membro desde: 08/07/13
22 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-1, Michaels Fall 2013 Membro de Ohio State, Team 1-1, Michaels Fall 2013
OSU-MICHAELS-F13S1G1
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 4,144
