Ir para o conteúdo principal
Kyocera Echo Front Screen Replacement
O que você precisa
  1. Kyocera Echo Front Screen Replacement, Front Screen: passo 1, imagem 1 %32 Kyocera Echo Front Screen Replacement, Front Screen: passo 1, imagem 2 %32
    • Orient the phone so that the screen is facing up. Place the metal spudger in the half-circle opening located near the bottom right of the Sprint logo at the top of the screen, identified with a red square.
  2. Kyocera Echo Front Screen Replacement: passo 2, imagem 1 %32
    • Gently wedge the metal spudger between the top screen and the phone to separate it. Continue wedging along the outside of the screen carefully with the metal spudger until the screen is apart.
Conclusão
Alex Kinstedt
Membro desde: 11/05/18
483 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S2-G6, Baechle Fall 2018 Membro de IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 182
