Introdução
Use this guide if you need to replace the camera in your Kyocera Echo smartphone. This guide should be taken slowly, as the general circuit board is glued to the screen. Removing this with the opening tool is easy to do without destroying it, as long as the user is careful.
O que você precisa
Orient the phone so that the screen is face down.
Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
Quase terminado!
Conclusão
