Ir para o conteúdo principal
Kwikset 450248 Battery Replacement
O que você precisa
  1. Kwikset 450248 Battery Replacement, Battery: passo 1, imagem 1 %32 Kwikset 450248 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Ensure you are changing the batteries on this model of the Kwikset digital door lock.
    • Prepare your AA batteries and flat head screwdriver before changing the battery.
  2. Kwikset 450248 Battery Replacement: passo 2, imagem 1 %32 Kwikset 450248 Battery Replacement: passo 2, imagem 2 %32 Kwikset 450248 Battery Replacement: passo 2, imagem 3 %32
    • Use your flathead screwdriver to pry your Kwikset door lock cover open.
    • Push up on the cover.
    • Slide the cover up to display the battery storage area.
  3. Kwikset 450248 Battery Replacement: passo 3, imagem 1 %32 Kwikset 450248 Battery Replacement: passo 3, imagem 2 %32
    • Grab the top of the battery storage area.
    • Pull the battery storage area out of the device.
  4. Kwikset 450248 Battery Replacement: passo 4, imagem 1 %32 Kwikset 450248 Battery Replacement: passo 4, imagem 2 %32
    • Remove all four batteries from the battery storage area.
    • Open the battery package and take four batteries out.
    • Place the new batteries into the battery storage area.
  5. Kwikset 450248 Battery Replacement: passo 5, imagem 1 %32
    • Put the battery storage device back into the Kwikset door lock.
    • Ensure the yellow label is facing you.
  6. Kwikset 450248 Battery Replacement: passo 6, imagem 1 %32
    • Slide the cover back onto the Kwikset digital door lock.
Conclusão
To ensure that the Kwikset digital door lock is reassembled properly turn the lock, and listen for the door lock to state door locked or door unlocked.
Taylor S. Matthews
Membro desde: 09/28/21
133 Reputação
Autoria de 1 guia
Equipe
UNT-Martin-F23S1G14 Membro de UNT-Martin-F23S1G14
Community
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 117
Duração total: 1,204
