Ir para o conteúdo principal
Kurio Xtreme Touch Screen Replacement
O que você precisa
  1. Kurio Xtreme Touch Screen Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Touch Screen Replacement: passo 2, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 2, imagem 2 %32
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Touch Screen Replacement: passo 3, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 3, imagem 2 %32 Kurio Xtreme Touch Screen Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Touch Screen Replacement, Touch Screen: passo 4, imagem 1 %32
    • Unscrew the three 4 mm screws with a Phillips #000 screwdriver.
  5. Kurio Xtreme Touch Screen Replacement: passo 5, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 5, imagem 2 %32
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Touch Screen Replacement: passo 6, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 6, imagem 2 %32
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Touch Screen Replacement: passo 7, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device and set it aside.
    • Be careful not to disconnect the black and red wires from the motherboard when setting the battery aside.
  8. Kurio Xtreme Touch Screen Replacement: passo 8, imagem 1 %32
    • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires. Set the speakers aside.
    • Be careful not to disconnect the black and red wires from the motherboard when setting the speakers aside.
  9. Kurio Xtreme Touch Screen Replacement: passo 9, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 9, imagem 2 %32
    • Remove the motherboard by lifting it out of the casing and set it aside along with the battery and speakers.
    • The motherboard will still be connected to the battery, speakers, and the gray ground wire.
  10. Kurio Xtreme Touch Screen Replacement: passo 10, imagem 1 %32
    • Carefully peel the ground wire tape off of the blue front screen panel.
    • It is not necessary to peel the tape off of the back of the silver LCD screen.
  11. Kurio Xtreme Touch Screen Replacement: passo 11, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 11, imagem 2 %32
    • Pry open all 7 of the blue clamps by wedging the plastic opening tool under them and bending them backward.
    • The clamps will not "snap" open. This step requires you to actually bend the plastic back.
  12. Kurio Xtreme Touch Screen Replacement: passo 12, imagem 1 %32 Kurio Xtreme Touch Screen Replacement: passo 12, imagem 2 %32
    • Remove the LCD display from the blue touch screen casing by gently shaking them apart in the palm of your hand.
    • This could be stuck on, so you need heat to loosen the glue.
    • Be careful when prying the digitzer from the plastic, if you bend it too much it can break the frame!
Conclusão
3 outras pessoas executaram este guia.
Mallory Myers
Membro desde: 09/22/15
1.190 Reputação
Autoria de 7 guias
Equipe
Baylor, Team 6-10, Williams Fall 2015 Membro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
Membros da 3
Autoria de 14 guias
2 comentários
Thanks - very good guide! For the investment of an iFixit toolset and less than 10 GBP for a replacement digitizer, I was able to restore my little boy's treasure!
Patrick Niessen - Responder
Thank you so much for the Guide!! Helped save Christmas!!! The steps were easy to follow and my kids tablets are back to new.
tdd82 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 3,387
