Ir para o conteúdo principal
Kurio Xtreme Speaker Replacement
O que você precisa
  1. Kurio Xtreme Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Speaker Replacement: passo 2, imagem 1 %32 Kurio Xtreme Speaker Replacement: passo 2, imagem 2 %32
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Speaker Replacement: passo 3, imagem 1 %32 Kurio Xtreme Speaker Replacement: passo 3, imagem 2 %32 Kurio Xtreme Speaker Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Speaker Replacement, Speaker: passo 4, imagem 1 %32 Kurio Xtreme Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Disconnect the 2 sets of black and red wires (4 wires total) from the motherboard by soldering the ends connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Speaker Replacement: passo 5, imagem 1 %32
    • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires.
Conclusão
Mallory Myers
Membro desde: 09/22/15
1.190 Reputação
Autoria de 7 guias
Equipe
Baylor, Team 6-10, Williams Fall 2015 Membro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 208
