Ir para o conteúdo principal
Kurio Xtreme Back Panel Replacement
O que você precisa
  1. Kurio Xtreme Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Back Panel Replacement: passo 2, imagem 1 %32 Kurio Xtreme Back Panel Replacement: passo 2, imagem 2 %32
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Back Panel Replacement: passo 3, imagem 1 %32 Kurio Xtreme Back Panel Replacement: passo 3, imagem 2 %32 Kurio Xtreme Back Panel Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Mallory Myers
Membro desde: 09/22/15
1.190 Reputação
Autoria de 7 guias
Equipe
Baylor, Team 6-10, Williams Fall 2015 Membro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 486
