Ir para o conteúdo principal
Kurio Touch 4S Front & Rear Facing Cameras Replacement
O que você precisa
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: passo 1, imagem 1 %32
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 2, imagem 1 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 2, imagem 2 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 2, imagem 3 %32
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 3, imagem 1 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 3, imagem 2 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 3, imagem 3 %32
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 4, imagem 1 %32
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 5, imagem 1 %32
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 7, imagem 1 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 7, imagem 2 %32
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 8, imagem 1 %32 Kurio Touch 4S Front & Rear Facing Cameras Replacement: passo 8, imagem 2 %32
    • Remove the copper wires by using the Tweezers to replace your new camera.
Conclusão
Uma outra pessoa concluiu este guia.
Khalid AlTamimi
Membro desde: 01/21/15
275 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-5, Brown Winter 2015 Membro de USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 262
