Ir para o conteúdo principal
Kurio 10S Motherboard Replacement
O que você precisa
  1. Kurio 10S Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Motherboard Replacement: passo 3, imagem 1 %32
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
  4. Kurio 10S Motherboard Replacement: passo 4, imagem 1 %32
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the electrical tape surrounding the battery.
  6. Kurio 10S Motherboard Replacement: passo 6, imagem 1 %32 Kurio 10S Motherboard Replacement: passo 6, imagem 2 %32
    • Locate the red and black wire connections where the battery is connected to the motherboard.
    • Now remove the red and black wires by soldering the ends of the wires off where they connect to the motherboard.
  7. Kurio 10S Motherboard Replacement: passo 7, imagem 1 %32
    • Locate and remove the copper tape connecting the motherboard to the back of the screen
  8. Kurio 10S Motherboard Replacement: passo 8, imagem 1 %32 Kurio 10S Motherboard Replacement: passo 8, imagem 2 %32 Kurio 10S Motherboard Replacement: passo 8, imagem 3 %32
    • Locate the ribbon cables connecting the motherboard to the screen and other peripherals.
    • Carefully lift the black part of the cable connector on the motherboard and pull the cable from the connector.
  9. Kurio 10S Motherboard Replacement: passo 9, imagem 1 %32
    • Locate and remove the four screws holding the motherboard on the device using the philips head screwdriver.
  10. Kurio 10S Motherboard Replacement: passo 10, imagem 1 %32
    • Locate and desolder the wires going to the speakers on each side of the device.
    • The motherboard can now be removed and replaced.
Conclusão
Ryan Kelley
Membro desde: 04/07/15
155 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-6, Shastany Spring 2015 Membro de UMass Dartmouth, Team 1-6, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G6
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,000
