Introdução
Removing the back cover allows easy access to many components inside of the device allowing you to fix other issues that may have popped up. This guide will show you how to remove your back cover and replace it if desired.
O que você precisa
Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
3 outras pessoas executaram este guia.
