Introdução
The trigger assembly that connects the button to the motor can sometimes break. This guide will explain how to replace the trigger assembly.
O que você precisa
In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
The trigger button is held in with light tension clips. Gently pry them back to release.
