Ir para o conteúdo principal
Krups F203 Coffee Grinder Plug/Cord Replacement
O que você precisa
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: passo 1, imagem 1 %32
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: passo 2, imagem 1 %32 Krups F203 Coffee Grinder Plug/Cord Replacement: passo 2, imagem 2 %32 Krups F203 Coffee Grinder Plug/Cord Replacement: passo 2, imagem 3 %32
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: passo 3, imagem 1 %32 Krups F203 Coffee Grinder Plug/Cord Replacement: passo 3, imagem 2 %32
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: passo 4, imagem 1 %32 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: passo 4, imagem 2 %32
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: passo 5, imagem 1 %32
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
Conclusão
Uma outra pessoa concluiu este guia.
Ian Hancock
Membro desde: 10/22/14
414 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 4-2, Williams Fall 2014 Membro de Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 2,930
