Ir para o conteúdo principal
Krups F203 Coffee Grinder Motor Replacement
O que você precisa
  1. Krups F203 Coffee Grinder Motor Replacement, Base Plate: passo 1, imagem 1 %32
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Motor Replacement: passo 2, imagem 1 %32 Krups F203 Coffee Grinder Motor Replacement: passo 2, imagem 2 %32 Krups F203 Coffee Grinder Motor Replacement: passo 2, imagem 3 %32
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Motor Replacement: passo 3, imagem 1 %32 Krups F203 Coffee Grinder Motor Replacement: passo 3, imagem 2 %32
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Motor Replacement, Detach Trigger Button from Base Plate: passo 4, imagem 1 %32
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Motor Replacement: passo 5, imagem 1 %32 Krups F203 Coffee Grinder Motor Replacement: passo 5, imagem 2 %32
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Motor Replacement: passo 6, imagem 1 %32
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
  7. Krups F203 Coffee Grinder Motor Replacement, Motor: passo 7, imagem 1 %32
    • Desolder remaining contact point from the plug cord
  8. Krups F203 Coffee Grinder Motor Replacement: passo 8, imagem 1 %32 Krups F203 Coffee Grinder Motor Replacement: passo 8, imagem 2 %32
    • Using a Phillips screwdriver, remove the two screws holding the motor in place.
  9. Krups F203 Coffee Grinder Motor Replacement: passo 9, imagem 1 %32
    • Remove the motor from the shell.
Conclusão
6 outras pessoas executaram este guia.
Ian Hancock
Membro desde: 10/22/14
414 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 4-2, Williams Fall 2014 Membro de Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
Membros da 3
Autoria de 8 guias
7 comentários
Doesn’t seem to apply to the Type 203. It looks different.
rpoland - Responder
The first photo of the bottom plate is too dark to show details. I have type 203 B Made in France and the clips didn’t budge without first breaking/stretching the thin outer walls of the base plate. No need to remove the wires. With mine, you have to turn the bottom shaft of the motor with a screwdriver (counter clockwise as usual) while holding the blade stationary which unscrews the blade from the motor enabling you to remove the motor after the two phillips screws are removed.
seeley6 - Responder
Hi Ian!
Nice explanation!
Can you provide a close up of the spudger that you used for opening the bottom plate?
I want to use the correct one, so I don ´t break that aged plastic cover.
Bengt
Yngve Lien - Responder
Where does one get the replacement motor?
Andrea Garrity - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 116
Duração total: 27,168
