Ir para o conteúdo principal
Krups F203 Coffee Grinder Base Plate Replacement
O que você precisa
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: passo 1, imagem 1 %32
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: passo 2, imagem 1 %32 Krups F203 Coffee Grinder Base Plate Replacement: passo 2, imagem 2 %32 Krups F203 Coffee Grinder Base Plate Replacement: passo 2, imagem 3 %32
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: passo 3, imagem 1 %32 Krups F203 Coffee Grinder Base Plate Replacement: passo 3, imagem 2 %32
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
Conclusão
9 outras pessoas executaram este guia.
Equipe
Baylor, Team 4-2, Williams Fall 2014 Membro de Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
Membros da 3
Autoria de 8 guias
10 comentários
Thanks! I was able to repair my broken cord.
wdswaim - Responder
I'mworking on it as we write .
jerry - Responder
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Responder
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Responder
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 52
Duração total: 11,269
