O que você precisa
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
Quase terminado!
Conclusão
Um comentário
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
