Ir para o conteúdo principal
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, imagem 1 %32 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, imagem 2 %32
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: passo 2, imagem 1 %32
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Conclusão
Hieu Ngo
Membro desde: 03/22/17
431 Reputação
Autoria de 4 guias
Equipe
Um comentário
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 27
Duração total: 1,040
