Ir para o conteúdo principal
Kolcraft Cloud Plus "Free-Stand" Button Replacement
O que você precisa
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: passo 1, imagem 1 %32 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: passo 1, imagem 2 %32
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 2, imagem 1 %32
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 3, imagem 1 %32
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 4, imagem 1 %32
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Conclusão
Equipe
Cal Poly, Team 11-1, Forte Fall 2015 Membro de Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 1,305
