Ir para o conteúdo principal
Kodak S100 EF Film Replacement
O que você precisa
  1. Kodak S100 EF Film Replacement, Film: passo 1, imagem 1 %32
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. Kodak S100 EF Film Replacement: passo 2, imagem 1 %32
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kodak S100 EF Film Replacement: passo 3, imagem 1 %32
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • Remove the old roll of film and slide in the new roll.
    • Push the roller back down to secure the film.
  4. Kodak S100 EF Film Replacement: passo 4, imagem 1 %32
    • To prepare the film for use, slightly pull the tail of the film out of the roll.
    • Drag the tail end of the film past the rotating column on the right side.
    • Attach the hooks at the base of the column to the holes located at the bottom of the film.
  5. Kodak S100 EF Film Replacement: passo 5, imagem 1 %32
    • After the film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
Conclusão
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Uma outra pessoa concluiu este guia.
Michelle
Membro desde: 04/04/11
107 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-28, Garner Spring 2011 Membro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 46
Duração total: 9,232
