Ir para o conteúdo principal
Kodak S100 EF Back Cover Replacement
O que você precisa
  1. Kodak S100 EF Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Kodak S100 EF Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Back Cover Replacement: passo 2, imagem 1 %32
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Back Cover Replacement: passo 3, imagem 1 %32
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
Conclusão
Michelle
Membro desde: 04/04/11
107 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-28, Garner Spring 2011 Membro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,581
