Ir para o conteúdo principal
Kodak PixPro AZ251 LCD Screen Replacement
O que você precisa
  1. Kodak PixPro AZ251 LCD Screen Replacement, Batteries: passo 1, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement, Batteries: passo 1, imagem 2 %32
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 LCD Screen Replacement: passo 2, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 2, imagem 2 %32
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the batteries.
  4. Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: passo 4, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: passo 4, imagem 2 %32 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: passo 4, imagem 3 %32
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 LCD Screen Replacement: passo 6, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 6, imagem 2 %32
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 LCD Screen Replacement: passo 7, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 7, imagem 2 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: passo 8, imagem 2 %32
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 LCD Screen Replacement: passo 9, imagem 1 %32
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 LCD Screen Replacement: passo 10, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 10, imagem 2 %32
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 LCD Screen Replacement: passo 11, imagem 1 %32 Kodak PixPro AZ251 LCD Screen Replacement: passo 11, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
Conclusão
Rachel Llewellyn
Membro desde: 02/22/18
509 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G1, Cagle Spring 2018 Membro de USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 2,075
