Ir para o conteúdo principal
Kodak Easyshare Z981 LCD Screen Replacement
O que você precisa
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Open the battery cover and remove batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 LCD Screen Replacement: passo 2, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 LCD Screen Replacement: passo 3, imagem 1 %32
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
  4. Kodak Easyshare Z981 LCD Screen Replacement: passo 4, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 4, imagem 2 %32
    $5.49
    Comprar
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  5. Kodak Easyshare Z981 LCD Screen Replacement: passo 5, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 5, imagem 2 %32
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  6. Kodak Easyshare Z981 LCD Screen Replacement: passo 6, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 6, imagem 2 %32
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
  7. Kodak Easyshare Z981 LCD Screen Replacement: passo 7, imagem 1 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 7, imagem 2 %32 Kodak Easyshare Z981 LCD Screen Replacement: passo 7, imagem 3 %32
    Comprar
    • Gently lift up the metal brace and use a pair to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Ramirez
Membro desde: 03/03/15
152 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 574
