Ir para o conteúdo principal
Kodak Easyshare Z981 Back Cover Replacement
O que você precisa
  1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
  2. Kodak Easyshare Z981 Back Cover Replacement: passo 2, imagem 1 %32
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
  3. Kodak Easyshare Z981 Back Cover Replacement: passo 3, imagem 1 %32 Kodak Easyshare Z981 Back Cover Replacement: passo 3, imagem 2 %32
    $5.49
    Comprar
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Back Cover Replacement: passo 4, imagem 1 %32 Kodak Easyshare Z981 Back Cover Replacement: passo 4, imagem 2 %32
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
Conclusão
Uma outra pessoa concluiu este guia.
Olivia Boyna
Membro desde: 03/03/15
509 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 627
