Ir para o conteúdo principal
Kodak Easyshare V1003 LCD Display Replacement
O que você precisa
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: passo 1, imagem 1 %32
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: passo 2, imagem 1 %32
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: passo 3, imagem 1 %32
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: passo 4, imagem 1 %32
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: passo 5, imagem 1 %32 Kodak Easyshare V1003  LCD Display Replacement: passo 5, imagem 2 %32
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: passo 6, imagem 1 %32 Kodak Easyshare V1003  LCD Display Replacement, Buttons: passo 6, imagem 2 %32 Kodak Easyshare V1003  LCD Display Replacement, Buttons: passo 6, imagem 3 %32
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: passo 7, imagem 1 %32 Kodak Easyshare V1003  LCD Display Replacement: passo 7, imagem 2 %32 Kodak Easyshare V1003  LCD Display Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: passo 8, imagem 1 %32 Kodak Easyshare V1003  LCD Display Replacement: passo 8, imagem 2 %32 Kodak Easyshare V1003  LCD Display Replacement: passo 8, imagem 3 %32
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: passo 9, imagem 1 %32
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: passo 10, imagem 1 %32
    • Take apart the LCD display from the back case.
Conclusão
Uma outra pessoa concluiu este guia.
Vanessa Soares
Membro desde: 03/15/17
222 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S9-G4, Martin Spring 2017 Membro de UMass Dartmouth, Team S9-G4, Martin Spring 2017
UMASSD-MARTIN-S17S9G4
Membros da 4
Autoria de 10 guias
Um comentário
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 34
Duração total: 725
