Ir para o conteúdo principal
Kodak EasyShare M381 Back Panel Frame Replacement
O que você precisa
  1. Kodak EasyShare M381 Back Panel Frame Replacement, Battery: passo 1, imagem 1 %32 Kodak EasyShare M381 Back Panel Frame Replacement, Battery: passo 1, imagem 2 %32
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Back Panel Frame Replacement: passo 2, imagem 1 %32
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: passo 3, imagem 1 %32 Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: passo 3, imagem 2 %32 Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: passo 3, imagem 3 %32
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Back Panel Frame Replacement: passo 4, imagem 1 %32 Kodak EasyShare M381 Back Panel Frame Replacement: passo 4, imagem 2 %32
    • Using both hands, carefully pull the frame apart from the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 322
