Ir para o conteúdo principal
Kodak EasyShare M2008 Lens Replacement
O que você precisa
  1. Kodak EasyShare M2008 Lens Replacement, Battery: passo 1, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement, Battery: passo 1, imagem 2 %32
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Lens Replacement: passo 2, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement: passo 2, imagem 2 %32
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Lens Replacement, Device Casing: passo 3, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement, Device Casing: passo 3, imagem 2 %32 Kodak EasyShare M2008 Lens Replacement, Device Casing: passo 3, imagem 3 %32
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Lens Replacement: passo 4, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement: passo 4, imagem 2 %32 Kodak EasyShare M2008 Lens Replacement: passo 4, imagem 3 %32
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Lens Replacement: passo 5, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement: passo 5, imagem 2 %32 Kodak EasyShare M2008 Lens Replacement: passo 5, imagem 3 %32
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Lens Replacement, Lens: passo 6, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement, Lens: passo 6, imagem 2 %32 Kodak EasyShare M2008 Lens Replacement, Lens: passo 6, imagem 3 %32
    • Remove screws from front silver panel.
  7. Kodak EasyShare M2008 Lens Replacement: passo 7, imagem 1 %32 Kodak EasyShare M2008 Lens Replacement: passo 7, imagem 2 %32 Kodak EasyShare M2008 Lens Replacement: passo 7, imagem 3 %32
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  8. Kodak EasyShare M2008 Lens Replacement: passo 8, imagem 1 %32
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Conclusão
Uma outra pessoa concluiu este guia.
Brian
Membro desde: 03/13/14
252 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 286
