Ir para o conteúdo principal
Kodak EasyShare M2008 Device Casing Replacement
O que você precisa
  1. Kodak EasyShare M2008 Device Casing Replacement, Battery: passo 1, imagem 1 %32 Kodak EasyShare M2008 Device Casing Replacement, Battery: passo 1, imagem 2 %32
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Device Casing Replacement: passo 2, imagem 1 %32 Kodak EasyShare M2008 Device Casing Replacement: passo 2, imagem 2 %32
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Device Casing Replacement, Device Casing: passo 3, imagem 1 %32 Kodak EasyShare M2008 Device Casing Replacement, Device Casing: passo 3, imagem 2 %32 Kodak EasyShare M2008 Device Casing Replacement, Device Casing: passo 3, imagem 3 %32
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Device Casing Replacement: passo 4, imagem 1 %32 Kodak EasyShare M2008 Device Casing Replacement: passo 4, imagem 2 %32 Kodak EasyShare M2008 Device Casing Replacement: passo 4, imagem 3 %32
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Device Casing Replacement: passo 5, imagem 1 %32 Kodak EasyShare M2008 Device Casing Replacement: passo 5, imagem 2 %32 Kodak EasyShare M2008 Device Casing Replacement: passo 5, imagem 3 %32
    • Remove screws along side.
    • Gently peel off side casing.
Conclusão
Kyanna
Membro desde: 03/13/14
313 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 162
