Ir para o conteúdo principal
Kodak EasyShare LS743 Top and Menu Button Replacement
O que você precisa
  1. Kodak EasyShare LS743 Top and Menu Button Replacement, Battery: passo 1, imagem 1 %32
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 2, imagem 1 %32
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 2 %32 Kodak EasyShare LS743 Top and Menu Button Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 4, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 4, imagem 2 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 4, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 5, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 5, imagem 2 %32
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Top and Menu Button Replacement, Top and menu buttons: passo 6, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement, Top and menu buttons: passo 6, imagem 2 %32
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 7, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 7, imagem 2 %32
    • Remove the top panel.
  8. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 8, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 8, imagem 2 %32
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 9, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 9, imagem 2 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 9, imagem 3 %32
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 10, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 10, imagem 2 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 10, imagem 3 %32
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 11, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 11, imagem 2 %32
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 12, imagem 1 %32
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Top and Menu Button Replacement: passo 13, imagem 1 %32 Kodak EasyShare LS743 Top and Menu Button Replacement: passo 13, imagem 2 %32
    • Pull the second orange tab from the circuit board and remove the buttons.
Conclusão
Uma outra pessoa concluiu este guia.
Michael
Membro desde: 06/24/10
63 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-8, Johann Summer 2010 Membro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,363
