Ir para o conteúdo principal
Kodak EasyShare LS743 Removing LCD Replacement
O que você precisa
  1. Kodak EasyShare LS743 Removing LCD Replacement, Battery: passo 1, imagem 1 %32
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Removing LCD Replacement: passo 2, imagem 1 %32
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 1 %32 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 2 %32 Kodak EasyShare LS743 Removing LCD Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Removing LCD Replacement: passo 4, imagem 1 %32 Kodak EasyShare LS743 Removing LCD Replacement: passo 4, imagem 2 %32 Kodak EasyShare LS743 Removing LCD Replacement: passo 4, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Removing LCD Replacement: passo 5, imagem 1 %32 Kodak EasyShare LS743 Removing LCD Replacement: passo 5, imagem 2 %32
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: passo 6, imagem 1 %32 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: passo 6, imagem 2 %32 Kodak EasyShare LS743 Removing LCD Replacement, Removing LCD: passo 6, imagem 3 %32
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 2-8, Johann Summer 2010 Membro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,256
