Ir para o conteúdo principal
Kodak EasyShare C913 Memory Card Replacement
  1. Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32 Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, imagem 3 %32
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open so be careful to lift it up gently.
  2. Kodak EasyShare C913 Memory Card Replacement: passo 2, imagem 1 %32 Kodak EasyShare C913 Memory Card Replacement: passo 2, imagem 2 %32
    • Push down on the memory card and it will spring up.
    • Grip and pull up the memory card to remove it.
Conclusão
Dustin Rodgers
Membro desde: 10/05/10
65 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-51, Amido Fall 2010 Membro de Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 2,590
