Introdução
Use this guide to remove the capacitor.
O que você precisa
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
Orient the camera with the lens facing you.
Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
Lift the plastic bridge off and place it to the side.
