Introdução
Removing and replacing the LCD and LCD casing.
Ferramentas
Peças
Não são necessárias peças.
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove 7 screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Put your thumb in the upper right corner of the LCD Screen.
Pull the LCD screen out of it's outer case with your thumb.
6 outras pessoas concluíram este guia.
