Ir para o conteúdo principal
Kodak EasyShare C713 Capacitor Replacement
O que você precisa
  1. Kodak EasyShare C713 Capacitor Replacement, Batteries: passo 1, imagem 1 %32
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Capacitor Replacement: passo 2, imagem 1 %32
    • Remove the old batteries.
  3. Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, imagem 1 %32 Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, imagem 2 %32 Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, imagem 3 %32
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Capacitor Replacement: passo 4, imagem 1 %32 Kodak EasyShare C713 Capacitor Replacement: passo 4, imagem 2 %32 Kodak EasyShare C713 Capacitor Replacement: passo 4, imagem 3 %32
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Capacitor Replacement, Capacitor: passo 5, imagem 1 %32 Kodak EasyShare C713 Capacitor Replacement, Capacitor: passo 5, imagem 2 %32
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
  6. Kodak EasyShare C713 Capacitor Replacement: passo 6, imagem 1 %32
    • Desolder points connecting capacitor to circuit board.
Conclusão
Equipe
Cal Poly, Team 26-19, Regan Spring 2010 Membro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 4,158
