Ir para o conteúdo principal
Kodak EasyShare C713 Buttons Replacement
O que você precisa
  1. Kodak EasyShare C713 Buttons Replacement, Batteries: passo 1, imagem 1 %32
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Buttons Replacement: passo 2, imagem 1 %32
    • Remove the old batteries.
  3. Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, imagem 1 %32 Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, imagem 2 %32 Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, imagem 3 %32
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Buttons Replacement: passo 4, imagem 1 %32 Kodak EasyShare C713 Buttons Replacement: passo 4, imagem 2 %32 Kodak EasyShare C713 Buttons Replacement: passo 4, imagem 3 %32
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Buttons Replacement, Buttons: passo 5, imagem 1 %32
    • Remove the necessary broken buttons.
    • They come out easily so just use your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Taggart Ashby
Membro desde: 04/15/10
354 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 26-19, Regan Spring 2010 Membro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,905
