Ir para o conteúdo principal
Kodak EasyShare C195 Batteries Replacement
O que você precisa
  1. Kodak EasyShare C195 Batteries Replacement, Batteries: passo 1, imagem 1 %32 Kodak EasyShare C195 Batteries Replacement, Batteries: passo 1, imagem 2 %32 Kodak EasyShare C195 Batteries Replacement, Batteries: passo 1, imagem 3 %32
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. Kodak EasyShare C195 Batteries Replacement: passo 2, imagem 1 %32 Kodak EasyShare C195 Batteries Replacement: passo 2, imagem 2 %32 Kodak EasyShare C195 Batteries Replacement: passo 2, imagem 3 %32
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. Kodak EasyShare C195 Batteries Replacement: passo 3, imagem 1 %32 Kodak EasyShare C195 Batteries Replacement: passo 3, imagem 2 %32 Kodak EasyShare C195 Batteries Replacement: passo 3, imagem 3 %32
    • When finished, you should have one battery positive side up and the other one negative side up.
Conclusão
To close the door, push the door down and slide to the right
Alyssa
Membro desde: 04/12/12
81 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-22, Amido Spring 2012 Membro de Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 51
Duração total: 3,064
