Introdução
This guide will help you fix a problem where the battery connection comes loose causing the Kobe Vox to not boot
You can also use this guide to replace the battery entirely.
O que você precisa
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
6 outras pessoas executaram este guia.
