Introdução
This guide shows how to remove/replace the rear cover on a Kobo Glo HD.
This guide applies to the Kobo Glo HD (model N437), but may also apply to the Kobo Touch 2.0 (model N587).
This guide does not apply to the regular Kobo Glo and Touch models.
O que você precisa
If you haven't done so already, power off your eReader by holding down the power button for 3 seconds until the display refreshes to indicate that it has powered off.
Start by inserting the pick into the area around the power button or Micro USB port.
Then, slide the pick around to undo these clips.
