Ir para o conteúdo principal
Introdução
Note that this is a teardown, so reversing this process is either very diffiuclt or impossible. Only proceed if you have no desire to reasemble the device afterwards.
Ferramentas
Peças
Nenhum componente especificado.
  1. Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Remove the screws from the midframe.
    • Remove the screws from the midframe.
  3. Use a nylon spudger to pry up the battery from the device.
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Unplug the battery connector from the rest of the tablet.
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Remove the screws that are attached to the grey plastic layer. Remove the gray plastic layer.
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Disconnect the speakers from the tablet.
    • Disconnect the speakers from the tablet.
  7. Wedge a nylon spudger between the screen and the tablet. Slide the spudger around the edges of the screen and remove it from the device.
    • Wedge a nylon spudger between the screen and the tablet.
    • Slide the spudger around the edges of the screen and remove it from the device.
Conclusão
Stephen Pehl
Membro desde: 28/10/2021
282 Reputação
2 Guias de autoria
Equipe
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Membros
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 54
