Ir para o conteúdo principal
Kobo Arc K107 Camera Replacement
O que você precisa
  1. Kobo Arc K107 Camera Replacement, Battery: passo 1, imagem 1 %32
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Camera Replacement: passo 2, imagem 1 %32
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Camera Replacement: passo 3, imagem 1 %32
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Camera Replacement: passo 4, imagem 1 %32
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Camera Replacement, Camera: passo 5, imagem 1 %32
    • Remove the motherboard from the outer case.
  6. Kobo Arc K107 Camera Replacement: passo 6, imagem 1 %32
    • Detach the old camera.
Conclusão
Ray Starpoli
Membro desde: 10/28/21
169 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 81
