Ir para o conteúdo principal
KitchenAid Professional 600 Top Cover Replacement
O que você precisa
  1. KitchenAid Professional 600 Top Cover Replacement, Top Cover: passo 1, imagem 1 %32
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Top Cover Replacement: passo 2, imagem 1 %32
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Top Cover Replacement: passo 3, imagem 1 %32
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
Conclusão
4 outras pessoas executaram este guia.
Luke
Membro desde: 04/11/16
1.353 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-4, Maness Spring 2016 Membro de Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 47
Duração total: 2,473
