Ir para o conteúdo principal
KitchenAid KUDS01DJSS0 Electronic Control Board Replacement
O que você precisa
  1. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: passo 1, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: passo 1, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: passo 1, imagem 3 %32
    • Unplug the dishwasher or shut off the house circuit breaker for the dishwasher.
    • To verify that power is disconnected, make sure that the control panel doesn’t light up when you press a control button or the power button.
  2. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 2, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 2, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 2, imagem 3 %32
    • Open the dishwasher door.
  3. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 3, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 3, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 3, imagem 3 %32
    • Remove the four screws from each side of the dishwasher door (eight screws total).
    • Removing the three screws from each side of the dishwasher (six screws total).
    • Support the outer door panel with one hand as you remove the final two screws at the top of the dishwasher door.
    • There are total of sixteen (16) screws.
  4. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 4, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 4, imagem 2 %32
    • Use your hands to pull off the outer door panel with the control panel.
  5. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 5, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 5, imagem 2 %32
    • Disconnect the two white outer wires by pulling them out.
    • The two white connectors have the same size and are close together.
    • Use one hand to hold the control panel while disconnecting the electrical connections from the old board.
  6. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 6, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 6, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 6, imagem 3 %32
    • Remove the white rectangular connector that has six colored wires connected to it.
  7. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 7, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 7, imagem 2 %32
    • Use one hand to hold the control panel while detaching the black connector.
    • The black connector is the main connector to the control board.
  8. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 8, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 8, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 8, imagem 3 %32
    • Detach the white and gray ribbon cable attached to the black connector.
  9. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 9, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 9, imagem 2 %32
    • Use your hands to pull the electronic control board out the mounting slots.
  10. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 10, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 10, imagem 2 %32
    • Push the new electronic control board into the mounting slots.
    • Slide it to the right to engage the locking tab until you hear a click.
  11. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 11, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 11, imagem 2 %32
    • Reconnect the black connector wires to the new electronic control board.
  12. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 12, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 12, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 12, imagem 3 %32
    • Reconnect the white rectangular connector with six wires to the new electronic control board.
  13. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 13, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 13, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 13, imagem 3 %32
    • Reconnect the two white outer connector wires to the new electronic control board.
  14. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 14, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 14, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 14, imagem 3 %32
    • Reinstall the outer door panel and control panel on the inner door panel and reattach the user interface control wire harness.
    • Reinstall the sixteen mounting screws.
  15. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 15, imagem 1 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 15, imagem 2 %32 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: passo 15, imagem 3 %32
    • Connect the dishwasher and reset the circuit breaker for your house to restore electricity.
    • To verify that power is connected, make sure that the control panel does light up when you press a control button or the power button.
Linha de Chegada
Thuan Trang
Membro desde: 01/13/22
345 Reputação
Autoria de 1 guia
Equipe
4 comentários
Excellent illustration!!!
KO SAMUEL TAK SHUN - Responder
عمل فنى رائع وجميل وبدقة متناهية
khaliddabnoun - Responder
عمل فنى جميل ورائع وبدقة متناهية
Excellent how to! However the part attached to purchase doesn’t look like the original control board. Help!
magdelena kormusis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 15
Últimos 30 dias: 47
Duração total: 1,433
