Ir para o conteúdo principal
KitchenAid KSM150PSER Speed Control Plate Replacement
O que você precisa
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: passo 1, imagem 1 %32 KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: passo 1, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: passo 2, imagem 1 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 2, imagem 2 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 2, imagem 3 %32
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: passo 3, imagem 1 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 3, imagem 2 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: passo 4, imagem 1 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 4, imagem 2 %32
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: passo 5, imagem 1 %32 KitchenAid KSM150PSER Speed Control Plate Replacement: passo 5, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: passo 6, imagem 1 %32
    • The control plate can now be removed by pulling back on the plate.
Conclusão
7 outras pessoas executaram este guia.
Richa Gadgil
Membro desde: 01/24/18
295 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
Membros da 4
Autoria de 10 guias
Um comentário
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 58
Últimos 30 dias: 223
Duração total: 18,662
