Ir para o conteúdo principal
KitchenAid KSM150PSER Power Cord Replacement
O que você precisa
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: passo 2, imagem 1 %32 KitchenAid KSM150PSER Power Cord Replacement: passo 2, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: passo 3, imagem 1 %32 KitchenAid KSM150PSER Power Cord Replacement: passo 3, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: passo 4, imagem 1 %32 KitchenAid KSM150PSER Power Cord Replacement: passo 4, imagem 2 %32
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Conclusão
Max Prohorov
Membro desde: 01/24/18
109 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 53
Duração total: 3,957
