Ir para o conteúdo principal
KitchenAid KSM150PSER Circuit Board Replacement
O que você precisa
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: passo 2, imagem 1 %32 KitchenAid KSM150PSER Circuit Board Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: passo 3, imagem 1 %32 KitchenAid KSM150PSER Circuit Board Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: passo 4, imagem 1 %32
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
Conclusão
4 outras pessoas executaram este guia.
Luke Leonard
Membro desde: 01/24/18
571 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 47
Duração total: 5,387
