Ir para o conteúdo principal
KitchenAid KSM150PSER Carbon Brushes Replacement
O que você precisa
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: passo 1, imagem 1 %32 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: passo 1, imagem 2 %32
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: passo 2, imagem 1 %32
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
Conclusão
6 outras pessoas executaram este guia.
Hayley Young
Membro desde: 12/03/16
211 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
Membros da 4
Autoria de 10 guias
Um comentário
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 47
Últimos 30 dias: 227
Duração total: 14,602
