Introdução
Removing the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
O que você precisa
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
Uma outra pessoa concluiu este guia.
