Ir para o conteúdo principal
KitchenAid KSB5CR Motor Replacement
O que você precisa
  1. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: passo 1, imagem 1 %32 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: passo 1, imagem 2 %32 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: passo 1, imagem 3 %32
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 2: passo 2, imagem 1 %32
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: passo 3, imagem 1 %32 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: passo 3, imagem 2 %32 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: passo 3, imagem 3 %32
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: passo 4, imagem 1 %32 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: passo 4, imagem 2 %32 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: passo 4, imagem 3 %32
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Motor Replacement, Removing the Fan: passo 5, imagem 1 %32
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
  6. KitchenAid KSB5CR Motor Replacement, Removing the Metal Cap: passo 6, imagem 1 %32
    • Use the needle nose pliers to turn the coupling clockwise to loosen it.
  7. KitchenAid KSB5CR Motor Replacement, Removing the Screws: passo 7, imagem 1 %32
    • Rotate the blender 90 degrees clockwise.
    • Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
  8. KitchenAid KSB5CR Motor Replacement, Detatching the Wire: passo 8, imagem 1 %32
    • Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
  9. KitchenAid KSB5CR Motor Replacement, Removing the Motor: passo 9, imagem 1 %32
    • Lift the motor up out of the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron Geehr
Membro desde: 09/28/14
745 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-5, Forte Fall 2014 Membro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 31
Duração total: 4,000
