Ir para o conteúdo principal
KitchenAid KHM512ER Motor Replacement
O que você precisa
  1. KitchenAid KHM512ER Motor Replacement, Motor: passo 1, imagem 1 %32 KitchenAid KHM512ER Motor Replacement, Motor: passo 1, imagem 2 %32
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Motor Replacement: passo 2, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 2, imagem 2 %32
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
  3. KitchenAid KHM512ER Motor Replacement: passo 3, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 3, imagem 2 %32
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  4. KitchenAid KHM512ER Motor Replacement: passo 4, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 4, imagem 2 %32 KitchenAid KHM512ER Motor Replacement: passo 4, imagem 3 %32
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
Conclusão
[deleted]
Membro desde: 02/10/16
134 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 35
Duração total: 4,560
