Introdução
Are your beaters not staying in? You may need to replace the beater rings.
O que você precisa
Insert the back of a plastic opening tool into one of the beater holes
Apply force to pull the circular plastic part off.
If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
4 outras pessoas executaram este guia.
3 comentários
Anyone know of a site that sells replacement beater gears?
try Sears parts.com
