Ir para o conteúdo principal
Kitchen Sink Basket Strainer Replacement
O que você precisa
  1. Kitchen Sink Basket Strainer Replacement, Basket Strainer: passo 1, imagem 1 %32
    • Shut off the hot and cold water supply valves under the sink.
    • Turn the handles clockwise and make sure the water is off before moving on.
  2. Kitchen Sink Basket Strainer Replacement: passo 2, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 2, imagem 2 %32
    • Remove the stopper from the basket strainer by lifting it out.
  3. Kitchen Sink Basket Strainer Replacement: passo 3, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 3, imagem 2 %32
    • Loosen the trap adapter nut under the sink.
    • Use the pliers and turn counterclockwise to loosen the nut.
  4. Kitchen Sink Basket Strainer Replacement: passo 4, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 4, imagem 2 %32
    • Loosen the tailpiece nut under the basket strainer.
  5. Kitchen Sink Basket Strainer Replacement: passo 5, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 5, imagem 2 %32
    • Loosen the nut of the basket strainer.
  6. Kitchen Sink Basket Strainer Replacement: passo 6, imagem 1 %32
    • Remove the basket strainer from the sink by lifting it out.
  7. Kitchen Sink Basket Strainer Replacement: passo 7, imagem 1 %32
    • Remove the tailpiece from the trap adaptor by lifting it out.
    • Keep the trap adapter nut and the nylon slip washer aside.
    • The trap adapter nut and nylon slip washer are shown in the image. The nylon slip is within the trap adaptor.
  8. Kitchen Sink Basket Strainer Replacement: passo 8, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 8, imagem 2 %32
    • Clean the sink opening and install a new basket strainer and the tailpiece.
    • Image 2 shows all the pieces that should be included in your new kit.
  9. Kitchen Sink Basket Strainer Replacement: passo 9, imagem 1 %32
    • Slide the old trap adaptor nut and nylon slip washer over the tailpiece.
  10. Kitchen Sink Basket Strainer Replacement: passo 10, imagem 1 %32
    • Install the tailpiece into the trap adaptor with the tailpiece washer inserted on top.
  11. Kitchen Sink Basket Strainer Replacement: passo 11, imagem 1 %32
    • Place the basket strainer on top of the tailpiece.
  12. Kitchen Sink Basket Strainer Replacement: passo 12, imagem 1 %32 Kitchen Sink Basket Strainer Replacement: passo 12, imagem 2 %32
    • Align the upper strainer to the basket under the sink and tighten it with the nut supplied.
    • Use the pliers and turn clockwise to tighten the nut.
  13. Kitchen Sink Basket Strainer Replacement: passo 13, imagem 1 %32
    • Tighten the tailpiece nut to the basket.
  14. Kitchen Sink Basket Strainer Replacement: passo 14, imagem 1 %32
    • Tighten the trap adaptor nut.
  15. Kitchen Sink Basket Strainer Replacement: passo 15, imagem 1 %32
    • Insert the strainer and turn the water back on to test for any leaks.
Linha de Chegada
Daniel Mella
Membro desde: 09/15/21
241 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 2,658
