Ir para o conteúdo principal
Kitchen Gourmet Waffle Maker Release Latch Spring Replacement
O que você precisa
  1. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement, Release Latch Spring: passo 1, imagem 1 %32
    • Unplug the waffle maker.
  2. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, imagem 3 %32
    • Open the waffle maker.
    • Make sure the waffle maker's surface is not hot.
  3. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, imagem 3 %32
    • Spray the interior of the waffle maker with cleaning solution.
    • Clean and wipe down the surface.
  4. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 4, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four screws that secure the plastic handle cover.
    • Spin in counterclockwise direction to loosen.
  5. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, imagem 3 %32
    • Carefully pull back the plastic cover, and gently remove the release latch.
  6. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 6, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 6, imagem 2 %32
    • Remove the spring from the latch.
  7. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, imagem 3 %32
    • Carefully replace with the new spring.
    • Pliers are recommended but removal with hands is fine.
    • Be careful not to bend the spring when pushing into the plastic handle.
  8. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, imagem 3 %32
    • Orient the release latch in the correct direction, and line up the spring.
  9. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, imagem 2 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, imagem 3 %32
    • Hold the latch in place.
    • Line up the screw holes on the plastic cover to the waffle maker lid.
  10. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 10, imagem 1 %32 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 10, imagem 2 %32
    • Screw in all four screws tightly.
    • Spin in clockwise direction to tighten.
    • Screw in opposing screws first to keep them in place.
Conclusão
Fatima Ruiz Ruiz
Membro desde: 02/01/24
193 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-4, Andersen Winter 2024 Membro de UC Davis, Team 3-4, Andersen Winter 2024
UCD-ANDERSEN-W24S3G4
3 Membros
1 Guia de autoria
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 215
